HELP! milky oil and water coming out of crankcase vent tube
I have a 1993 f150 xlt with a 351w. Everything was bone stock when I got it and only 147xxx miles on it. When I went to change the air filter about a year ago I noticed that there was a few drops of oil in the airbox and the air filter and breather filter were soaked with oil I changed the filters, cleaned the airbox and the crankcase vent tube and I thought it was fine for a couple of months, until I noticed it was still filling up with oil I looked online and bought a cheap oil catch can from amazon.com and installed it in line with the CCV tube. It kept the airbox clean, but I noticed that there was water and milky oil in the can. i tried to stop some of the liquid from entering the airbox by putting a 3/8 fuel filter in between the oil catch can and airbox. I decided to try and find the culprit responsible for this problem, so I looked around the engine and found that there was some coolant sitting on the engine next to the waterpump, and the thermostat housing was wet around the gasket. I replaced the housing, thermostat and gasket and also added some RTV gasket maker. the leak was stopped at the housing but there is now a few drops of coolant on the water pump gasket every time I drive and there is still milky oil coming out of the CCV tube. Does anyone have any suggestions or ideas on how to fix this?
I tried replacing the PCV valve with a Microgard PCV valve from O'Reilly's and it ended up forcing oil out of the dipstick tube (I read that these trucks only like to use Motorcraft PCVs )so I put the old one back in for now and it fixed that problem, but I will put a new one in when I find one. I havent seen any water in the oil or on the dipstick, just in the oil catch can. I will try the oil cap thing soon and see if it works.
on
on
is this the upper or lower hose on the Pcv valve that goes to the manifold?
However, the hose is irrelevant. The hose is not what is getting plugged up, it is the metal port that is screwed into the back of the upper manifold plenum that is at fault.
Here' my take on it & You can take it for what its worth.
On my 94, the vacuum/pcv set up is reversed from what you have. The Vac tree is to the rear & has ALL the vac lines including the brake booster line & the MAP sensor line (which appears to be by its self) go to it with the PVC going to a single nipple in the front.
I figure Ford had a reason for this change.
Also, I would check the hose that runs diagonally & around the back to the PCV valve for obstruction.
*** Check that, I don't see WHERE your PCV line enters the upper intake???
