1958 f250 front break drum
Old 01-22-2017, 12:46 PM
peewee46's Avatar
peewee46
peewee46 is offline
Has anyone taken apart a front break drum ? The drum and bearing race are two seperate pieces held togeather with flathead straight slot screws.i am affraid to mess with them unless i can get new screws
Old 01-24-2017, 05:36 AM
jollygreen_giant's Avatar
jollygreen_giant
jollygreen_giant is offline
I rebuilt the rear in my 59 250 and got all the parts from the local auto parts store. The screws where the least of my problems though. I ended up having to torch the case to get it off after removing the screws and cracked the drum.. It is replaceable as well. This is as long as you are talking about the 3 screws on outside of the drum. I just hit them with penetrating lube and they came right out.
Old 01-25-2017, 03:44 AM
Col Flashman's Avatar
Col Flashman
Col Flashman is offline
The last time I took mine apart friction is what held the drum in place, not screws.
You should just be able to tap the drum off w/ a mallet.
Old 01-25-2017, 10:00 PM
Joshua1960's Avatar
Joshua1960
Joshua1960 is offline
Use a deadblow hammer or a puller.
Old 01-28-2017, 08:43 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
I bought the big flat tip screws on the face of the drum at Ace hardware.
Jasonlandon12345
21
05-06-2017 10:14 AM
teardropty
11-14-2010 03:47 PM
67 Merc 4X4
04-05-2009 07:21 AM
mason55
03-21-2007 10:46 PM
wckdclwn911
06-29-2004 12:59 PM
Quick Reply: 1958 f250 front break drum
