1978 - 1996 Big Bronco
1978 F150 Headlights
Old 01-22-2017, 08:13 AM
fishbeard's Avatar
fishbeard
fishbeard is offline
Both headlights went out as I pulled the **** turning them on. All other lights work fine, just no headlights high or low.
Trying to locate fuze / relay
Any Ideas?
Old 01-22-2017, 06:14 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Trace wiring back from headlights, find common point where they meet up and look for a broken wire from there.
Old 01-22-2017, 06:24 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Pull the headlamp switch **** all the way out, step on the floor mounted dimmer switch, then see what happens.
The switch corrodes, so if the low beams are on and you step on the switch, the headlights will go out...and vice versa.
Old 01-30-2017, 07:40 PM
martinbarrio's Avatar
martinbarrio
martinbarrio is offline
yes its either the dimmer switch or the headlight switch. very common place for headlight problems.
Eddillard79
07-26-2015 02:41 PM
1979Ford33
08-19-2014 06:38 PM
blucollar4xford
Electrical Systems/Wiring
01-08-2011 08:40 AM
GarageFab
02-15-2010 10:17 AM
horses4fun2
12-31-2004 08:06 AM
Quick Reply: 1978 F150 Headlights
