1978 F150 Headlights
01-22-2017, 08:13 AM
on
Both headlights went out as I pulled the **** turning them on. All other lights work fine, just no headlights high or low.
Trying to locate fuze / relay
Any Ideas?
01-22-2017, 06:14 PM
Trace wiring back from headlights, find common point where they meet up and look for a broken wire from there.
01-22-2017, 06:24 PM
Quote:
Originally Posted by
fishbeard
Pull the headlamp switch **** all the way out, step on the floor mounted dimmer switch, then see what happens.
The switch corrodes, so if the low beams are on and you step on the switch, the headlights will go out...and vice versa.
01-30-2017, 07:40 PM
on
yes its either the dimmer switch or the headlight switch. very common place for headlight problems.
Eddillard79
07-26-2015 02:41 PM
1979Ford33
08-19-2014 06:38 PM
blucollar4xford
Electrical Systems/Wiring
01-08-2011 08:40 AM
GarageFab
02-15-2010 10:17 AM
horses4fun2
12-31-2004 08:06 AM
