Looking for a F600 vacuum gauge.
D0TZ-2557-A .. Brake Air Pressure Gauge / Marked: D0TF-2557-A / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
Applications: 1970/72 F600/750 & C600/900; 1973/74 F600/880 & C600/900; 1975 F600/880 & C600/900 before serial number V40,001.
D0TZ-2A036-A .. Brake Vacuum Gauge / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
Applications: 1970/74 F500/750 & C500/900; 1975 F500/750 & C500/750 before serial number V40,001.
Note: In 1975 from serial number V40,001, Ford replaced both these D0TZ gauges with 1975 gauges (D5TZ-2557-B & D5HZ-2A036-A = Obsolete, but both are available NOS).
Lower pic from 1964/72 catalog showing both types of vacuum gauges as: 2557 & 2A036 / 17360 on the right side of the cluster is a tach.
This one (in the fore ground) that resides in Florida now.
And this one that went to California.
Around '78, the big truck instrument clusters went from the hardwire connections to a printed circuit cluster. This is a printed circuit cluster I pulled from a '78 F600 fire truck. This cluster went to Connecticut.
...printed circuit on the back of this '78 F600 cluster.
I did an internet search but, all I can locate is an NOS pressure gauge but no listings for an NOS or used vacuum gauge for one of these instrument clusters. Good luck in your search in locating one.
That's usually the way it goes. If you're not looking for something at the moment, they're everywhere. The instant you are on the hunt for something, it can't be found.
D5HZ-2A036-A (replaced D0TZ-2A036-A) .. Brake Vacuum Gauge / Obsolete
BOB ALLEN FORD in Overland Park KS has 1 = 913-381-2999.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
D5TZ-2557-B (replaced D0TZ-2557-A) .. Brake Air Pressure Gauge / Obsolete
GREEN SALES CO. has 1.
KOEHN MOTORS in Wellington KS has 1 = 620-326-5915.
D5HZ-2A036-A: Call Bob Allen first, then whatever Green Sales wants should be much cheaper. Allen is a snake, wants MEGA-BUCKS for obsolete parts!
Ford website has prices listed for D5HZ-2A036-A (Last MSRP: $209.40 / Dealer net cost: $125.64) but none for D5TZ-2557-B
'Course you really won't know 'how much' until you call.
D5TZ-2557-B: Call Green first, Koehn may be cheaper, since they are STUCK with it.
