Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-27-2003, 09:29 PM
FLOW_BOY is starting off with a positive reputation.
Smoking A/C Compressor
I had some trouble with my brakes the other day. Bad brake line. Easy enough to find and fix.
When I noticed the brake problem (girl friend driving??) I asked her to pull over (she didn't notice there were no brakes). As we pulled into a parking lot, I saw some smoke coming from under the hood. A/C compressor was smoking from the pulley end. I figure this was a coincidence.
1. Could the A/C problem have been related to the brake problem?
2. What is the probable fix for the problem (clutch, compressor)?
Any ideas?
thanks
__________________
1994 EB Bronco
EFI 351w
8.8" Limited Slip 4.11 Rear
TTB Dana 44 Front
6" Skyjacker Class II Sys.
33" BFG's
Edelbrock Stainless Headers
Bassani Stainless y-pipe/cat/cat-back
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-27-2003, 09:46 PM
bronco351 is starting off with a positive reputation.
Your problem is very simple. Your A/C compressor clutch is slipping, causing it to heat up and smoke. The only way to fix it is to change the clutch or put in a new A/C compressor!! Have a great day!!
__________________
-1998 Ford P71, THIS CAR IS SCAREY FAST!!!
-2003 F-350 Dually, Crew Cab, Turbo Diesel, 4x4, BLACK!!!
  #3 (permalink)
Old 08-28-2003, 01:12 AM
crussel4 is starting off with a positive reputation.
I agree with Bronco351, it's the clutch on the compressor.
Don't put it off or you'll ruin the compressor.
  #4 (permalink)
Old 08-29-2003, 08:08 PM
I had a mechanic look at the compressor. He said that they ran the compressor for 10-15 minutes and had no problems. But said that he could see marks from when it had smoked. Diagnosis - the compressor is starting to go (seize) and causing the clutch to slip, get a new one (compressor).
Does that seem right, or can the clutch be replaced easily?, and if it can be replaced, is that likely to solve the problem for any length of time?
Thanks
__________________
1994 EB Bronco
EFI 351w
TTB Dana 44 Front
33" BFG's
  #5 (permalink)
Old 08-29-2003, 10:40 PM
craterjoe is starting off with a positive reputation.
A second opinion may not be a bad idea.......
__________________
Craterjoe
1996 Bronco XL 5.0 E4OD
No Matter Where You Go There You Are ... Buckaroo Banzai
  #6 (permalink)
Old 12-26-2003, 02:24 PM
nowbiteme is starting off with a positive reputation.
Hi:
I am experiencing the same problem(smoking a/c compressor). Is it possible to just change the belts and bypass the compressor all together? Any difference in performance??
And when i do get a new compressor, will it matter if i want to convert from r-12 to r-136? I assume when the old compressor is removed, they will have to capture all the existing r-12.
thx.
  #7 (permalink)
Old 12-26-2003, 04:55 PM
battered_bronco is starting off with a positive reputation.
i'd say she broke it
friggin women have to use the AC!!!!!!
aint you got windows
__________________
335 series = pure americian power(and/or torque)
  #8 (permalink)
Old 12-28-2003, 10:50 AM
I would think there is a shorterbelt that you could get to bypass the a/c comp. question is will it clear the a/c comp if you leave it in place?
I would recommend converting from r-12 to r-134a simplty on a financiial standpiont when my mom had it done a couple of years ago it was only +/- $200 but save a load on what the replcement r-12 would have cost. and if you ever have a leak.......
__________________
Craterjoe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
