Changing gears
+1 on 3.55s. Presumably you have 4.10s now? (Should have mentioned in opening post...) 4.10 -> 3.73 isn't enough of a gain to be worth the effort. And the truck never came with 3.73s, so it'd be hard to find a set.
To install an E4OD, you'd need the TCM and all the wiring as well, and the TPS on injection pump, etc. Not an elementary job. If you're willing to shift, a ZF5 swap might actually be less work.
You can get gears for any Ford axle in a wide range of ratios. Assuming it's a 10.25, you can get 3.55, 3.73, 4.10, 4.30, 4.56, 4.88, 5.13 and 5.38.
Being a 4x4, that's two gear sets to change, and the rear at the very least must be new. If you try to install used gears and don't exactly match the pattern, the gears will grind themselves apart in a very short time. It's not as critical in the front on a truck with locking hubs, but not something I would do lightly. You can also swap the entire axle assembly, but chances are very good you will not find a D60 front end from a Ford with anything other than 4.10 gears.
xjpilot
12-06-2011 04:46 PM
turboman24
13
11-03-2007 02:49 AM
leftystar
08-01-2006 03:20 PM
shane74
01-11-2004 10:29 PM
