Oil In The Air Intake Outlet Tube
I removed the air intake outlet tube (the one between the air filter and engine). It had a fine coating of oil inside and there was some minor puddling of oil sitting in the tube's creases. No oil present on or near the actual air filter.
Is this normal? If not, what is causing it and will it cause a major problem in the short term? What is the fix for it?
I also noticed oil (looked like leakage) around the rectangular base where the air intake tube seems to connect to the engine. What's going on here?
BTW - engine runs clean and does not blow excessive smoke except occasionally at start up you might briefly notice some smoke if its been sitting for a few days. There is some oil loss between my 6,000 mi. oil changes (I'm guessing perhaps a quart or two).
This is completely normal. The CCV does put oil into your intake system. As long as there isn't swimming pools worth of oil in your intake it should be fine
As for that rectangle box, that is where your CCV comes from the engine. There are o-rings in there that can be replaced to stop your leak
I looked at the acronym page from the tech folder ... couldn't find CCV so I'm going to guess ... is it Crank Case Vent?
Also, is replacing the o-rings an urgent or difficult tough job? It's winter here in the Great White North and I prefer tackling this job in Spring if possible.
Yes, its normal to have some oil residue in the Air intake piping. The Air intake just beyond the accordion piping toward the Turbo is tied into the CCV/dog house on the valve cover. At this point is where the engine breaths. It exhales a slight oil misted air back into the Air intake system and is sucked back into the engine by the turbo. The oil tends to sit in the lowest part of the Air intake system. Most of us will clean the oil out as part of the filter cleaning/changing maintenance process.
The fix is to run a 3/4" hose from the CCV doghouse on the valve cover to a
1. Catch can. This requires you check and or empty the catch can at oil changing intervals.
2. Vent it out to air somewhere down the frame rail.
3. Run the hose to a welded bung on the exhaust system.
The following is of course is you see excessive smoke at idle or under acceleration.
1. Blue/Gray smoke: Oil being burned
2. Gray/White smoke: is coolant in the exhaust system.
3. Black smoke: is an indication of excessive fuel.
The exhaust smoke your exhibiting sounds completely normal though. Just my opinion. Hopefully this helps yah some.
On edit; a Dirty Air filter will cause some oil consumption, something I feel that some folks tend forget to do or check because we've pushed towards longer oil drain intervals with running sythetics.
1984F2506.9
05-10-2014 11:27 PM
