replacement shocks for F250 4x4 with 6" lift kit
I am looking to buy replacement shocks for my 1977.5 F250 4x4. Its been a few years and the marketplace has changed.
Some quick internet searches found Skyjacker, Superlift, and Rough Country still offer shocks for a 6" lift using factory shock mounts.
Does any one have some good advice? or other options to consider?
Thanks.
Thanks.
What are the upper and lower shock mounts? I had a really hard time finding front shocks with stud mount top and bottom for a 4" lift. You may want to start looking at full spec sheets and go by top mount, bottom mount and length rather than someone's suggestion of a shock that is suppose to work. I went to into 4 wheel parts and they wouldn't even believe me about what I needed/had. I had to walk out when they told me they couldn't get me shocks until I changed the shock mounts
Note 1: Yes, I plan to keep the original-factory shock mounts
Note 2: With the 6" lift it becomes a "custom shock" and normal parts stores do not sell anything close the the needed travel length, compression to retro fit. I checked several websites and the Monroe shock master data sheets.
Seems like Skyjacker, Super Lift, and Rough Country are the last providers of this item.
Option B. Change the shock mounts, custom fab so that a factory size shock from another vehicle would would and thus be available in any parts store.
Yes looks like a standard/OEM mount set up shock (stud and stud on the front) and (top stud and bottom bolt) on the rear.
The rear looks to me a custom leaf pack, because even on a Skyjacker 6" you have to reuse the OEM block and the rear block does not look OEM height.
I also see rear disk brakes and what looks like traction or ladder bar axle brackets, nice.
Deaver Spring | Leaf Springs, Suspension, 4x4 Off Roading
1967 - 1979 F250 leaf springs - front and rear
Ck out Atlas...they have the option to delete the rear block all together. 1973-1979 F250//F350 4x4 Atlas SuspensionAtlas Spring Company
F350moneypit
10-03-2017 05:51 PM
Jimmyrig
03-12-2013 10:49 PM
crewcabdave
10-04-2011 04:33 PM
