I have a 1997 f150 Lariat truck. I was wondering how to turn off or quite the turn signal noise/sound. I'm not sure if it's in the instrument cluster or elsewhere.
There are two different flashers, one for the turn signals, one for the 4 way emergency flashers. Both look the same, but the 4 way flasher is a heavy duty unit, has a louder CLICK.
But the 4 way flasher was also used as the T/S flasher on Camper Specials and/or with trailer tow or installed for people that are deaf.
So most likely your T/S flasher is the 4 way heavy duty type. Replace it w/the T/S flasher that is barely audible.
