Assembled before disassembly........
Quick project update. Spent most of the winter so far getting the panel gaps and fits right. Just the hood to cowl left to do. Will be removing the bed and front clip this weekend and once nood to cowl is done the cab will come off ready for engine, transmission rebuild and frame completion. Some progress photos -
Thanks for positive comments, appreciated. The FFR is a MKII finished 2010. I'm running a built 306. Fully balanced rotating assembly, Trick Flow heads and Edelbrock RPM intake with QFT carb. MSD distributor and ignition. T5 transmission with 8.8 LSD 3.55 rear end.
A bucket full of fun!!! Check out hundreds of photos in the link.
John Brown's Library | Photobucket
