quick...easy question...on door seals
and this kit on ebay is the right seals? I emailed them to check and they pretty much replied the with the listings description
Door Window Sweep Weatherstrip Seal Kit for 87-96 Bronco F-Series Pickup Truck | eBay
The LMC door seals are most likely Chinese-made cr@p. OEM is not much more expensive and is WAAAY better quality. Made in Canada. Try the online dealerships; I think I got mine from AutoNation White Bear Lake (AFTER returning the cheap Chinese ones to Dennis Carpenter).
I would be VERY wary of that eBay item. Look at the window felts, the ones that snap into the door. There are supposed to be two with four clips and two with five clips. The outers have four clips and the inners have five (or maybe it's vice-vers). So either that pic is wrong, or you're getting the wrong part. Another aftermarket part I'd be very skeptical of. I picked up a set of these from DC a while ago and installed the outers right away because the truck needed them. They were very good quality. I went to do the inners just recently, and they sucked. Cheap and flimsy construction, didn't have the same shape as OEM so wouldn't fit right, and they used the wrong clips.
DW SD
24
12-02-2018 11:12 AM
