How can it be done?
How can it be done?
PJ Trailers | 8" Channel Equipment
I am want to be able to pull two Jeeps with my truck. Seems no matter what I do I overload the truck or the hitch. The above trailer can come with a 3rd axle. Giving me more than enough to haul two 5000# Jeeps (2drs). I think I can fit them on a 24 foot trailer. That should put me at 13K#. Which I believe is just out of spec for the factory hitch.
PJ Trailers | Classic Flatdeck with Singles
PJ Trailers | Classic Flatdeck with Duals
If I go with the above goosenecks the trailer weighs more. Then it will be closer to 16K. which is out of spec for the truck. (2013 6.2L 2wd w/ 3.73)
Thoughts, Opinions, suggestions!!!! Don't hold back!
https://www.fleet.ford.com/resources...Tgde_Oct19.pdf
How is that possible unless the years are different. Reading this from Ford I would think 12,500 from the hitch (with weight distributing hitch) & 15,400 if I swap out to 4.30 gears.
Like it! Was wondering if there was something out there like this.
I might if I was staying on a farm or local urban roads. I live in near Chicago. Last year trailered to Utah through Denver mountains. This year Ouray CO is set. Also a trip to AR & TN possible. Not to mention the several trips just a 2 to 4 hours away. I don't mind pushing the limits but a life isn't worth me getting another Jeep to my location.
I guess my point was that you are looking at going a little bit over, where as I was nearly double.
there's more headroom in that rating than you'd think.
Had them weighed at a CAT scale.
Base curb weight is 3900#. Not sure if that is with fluids. Start adding tires, bumpers, winch, and a full skid plate pkg and they turn into heffers.
You're not going to kill anyone because you can't accelerate fast enough. It would be a bit pokey off the line, but once your RPMs came up in first gear you should be fine. You won't be fastest up the mountain, but you'll get there every bit as safely as anyone else in an SRW truck.
Watch your axle weights and your hitch weight limits. If you're under those you should be fine.
pwrstrker
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
03-29-2001 07:02 AM
