82 F-150 302 off-idle hesitation
Old 01-18-2017, 10:56 PM
Lazyace's Avatar
Lazyace
Lazyace is offline
I got an off-idle hesitation every time I let off the accelerator and press back on it like when I slow for cornering or full stops. Seems worse when engine is warmed up. Could it be carb or vacuum advance problem? Thanks.
Old 01-19-2017, 07:04 PM
Lazyace's Avatar
Lazyace
Lazyace is offline
Come fellas, Anybody?
Old 01-19-2017, 08:12 PM
baddad457's Avatar
baddad457
baddad457 is offline
Check for slack between the accelerator pump and throttle linkage . Retarded Timing can also cause this. Vacuum advance is easy to diagnose, remove the distributor cap, pull the vacuum hose to it loose at it's source (front hose on the distributor if there's two, pull loose where it leads to from the distributor) Then while watching the advance mechanism inside the distributor, suck on the hose and see if the breaker plate moves inside the distributor. If it does not move, the plate is either stuck or the vacuum diaphragm is ruptured. The vacuum diaphragm pod can be changed by itself.
Old 01-19-2017, 08:16 PM
Lazyace's Avatar
Lazyace
Lazyace is offline
OK. I'll try that tomorrow and post my results later. Gives me a starting point anyway. Thanks alot.
Old 01-19-2017, 09:11 PM
Lazyace's Avatar
Lazyace
Lazyace is offline
OK, I did exactly what you said but I checked the vacuum line first and it was cracked so I used a good peace of hose and it didn't move but I heard the air leaking out the diaphragm so it's a busted diaphragm. Now I know what's wrong just gotta find the time to fix it 😏. Thanks again baddad457.
Old 01-20-2017, 07:07 AM
baddad457's Avatar
baddad457
You should be able to buy just the vacuum pod at the parts house. I changed one several years ago and got it at the local Advance Auto Parts. Hopefully for your sake they still do. Or look one up online
Light Doug
11-19-2018 05:20 AM
Jackpom
05-13-2015 10:42 PM
dusted800
03-06-2004 07:43 AM
19Ford69
02-15-2004 07:12 PM
atblis
08-02-2001 10:21 PM
Quick Reply: 82 F-150 302 off-idle hesitation
