Help from anybody running Dual Webber Setup
Old 01-18-2017, 12:26 PM
80ford100's Avatar
80ford100
80ford100 is offline
Getting close to starting my 300 build that has a Webber dual setup on it. I'm running a Holley red electric fuel pump with the regulator supplied. I would like some info on how to setup the regulator for initial start up. What pressure and where to install a pressure gauge and what not. Also what adjustments need to be made to the carbs.
Thanks, John
Old 01-22-2017, 06:32 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,085 Likes on 1,778 Posts
I hear the Weber carbs don't like much above 4 psi so the regulator with the gauge on the outlet has to be before the carbs.
Because you have to run 2 fuel lines I think they make a block "Y" with a port you can install a gauge so you can tell what the PSI is at that point.
DO NOT mount the fuel PSI gauge inside the truck! They make isolators to mount the fuel side in the engine bay and just run the gauge and the hose from the isolator inside.
As for the 2 carbs cant help much but I know they both have to pull the same amount of air. Just did a quick Google search and came up with this.
How to Synchronize Dual Carburetors | Chirco.com News
Dave ----
70-360fe
15
03-04-2014 12:17 AM
High Binder
11-06-2010 09:06 PM
Fordbronco69
34
02-24-2010 08:19 AM
war thunder
08-02-2007 11:40 PM
sean23johnson
13
11-17-2006 05:50 AM
Quick Reply: Help from anybody running Dual Webber Setup
