After changing the timing chains, guides, lash adjusters, I put it all together and didn't notice I pulled the capacitor off the harness on the driver's side. After putting it all together, the driver's side is dead. Would a missing cap. cause this?
No all that is for is preventing RF noise through the radio. You need to verify the cams are right. As I said before, if you set both sides to the L on the phasers then one side is 180 degrees out.
Thanks for the reply. Just double checking everything before I pull the valve cover again. Which I did and it looks like I'm an idiot that can't match two shapes together. Definitely a low point for me. Thanks for the help.
I just went back and re-watched the video on u-tub by FordTechMakuloco and he did exactly what you said I did by lining up the "L" on both heads. Problem is I didn't line up the "L" on the right head. I was at the line. So which is it?
