4wd hub seals/ replacement
Old 01-17-2017, 08:42 PM
88_F0RD's Avatar
88_F0RD
88_F0RD is offline
where do you get replacement seals for 4wd hubs?
need to remove the axles to replace some inner seals on my solid front axle, and have to remove everything, but where do you get replacment seals for the 4WD hubs, or are they needed?
not really sure if they have a seal, but dont wanna buy new hubs.
Old 01-17-2017, 08:57 PM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
On my Warn's, there is an O-ring on the lockout that seals to the ID of the hub. I'm not sure where to source them without buying a hub service kit, but I'd think a suitable o-ring could be found with a little digging.
Side question: Which front axle did you swap in?
Old 01-18-2017, 08:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,354 Likes on 1,069 Posts
Warn sells a service kit for their hubs which usually includes the seals and screws.
Old 01-18-2017, 03:56 PM
88_F0RD's Avatar
88_F0RD
88_F0RD is offline
not sure
I'm not quite sure what the front axle is, havent checked the tag,
when I replaced the wheel seal on the rear axle, I did find the tag, and wrote in down in my Haynes manual what type it was,
the only reason I'm pulling the stock axles, is to change the seals on the side of the differential. Seems like one side is leaking, and the gasket around the solid axle is leaking, looks like someone took it apart before, and put orange sealer, or red rtv, instead of black oil resistant RTV.
just noticed it not too long ago, and havent added any oil to it, really wanna change the seals inside,
any good write up of changing those seals that go out to each side of the wheel?
I cant even think of what the part is called now.
gvanderlugt
6.2L V8
07-01-2018 04:25 PM
powerstroker02
1999 to 2016 Super Duty
02-26-2015 06:49 PM
fishintheobx
09-28-2012 08:01 PM
john8403
06-25-2011 01:37 PM
daan-o
15
01-22-2011 01:00 PM
Quick Reply: 4wd hub seals/ replacement
