Idi Turbo kit value
I was able to install the turbo kit today. With my pump maxed I was making ten pounds of boost at wot, 12 on hills. To be honest I'm not all that impressed so I took it back off and am going to consider a better route. The power gains weren't as much as I expected....
I will definitely sort the vans parts and post them up eventually. May have even found a line on a set of van hotpipes.
I would possibly be interested in the van parts once you get them sorted out.
Received 3,102 Likes
on
on
One thing I didn't like is there's not a lot of room for a down pipe on my body style (85)
I tried denting the firewall with a 6' prybar but the whole thing just flexed, it's amazing I haven't had to do the clutch master cylinder plate yet, probably due to the fact that I have a smf not a dual.
I'd like something in the likes of 20-25 but I need studs and my motor already has too many miles plus she's starting to breathe a little. I just put an engine in it not too long ago I just went the cheap route until I have the time to actually build a motor.
I think some cowl massaging and a hx35w turbo would match up nicely. They bolt up to the banks pedestal too.
if I were you, I would really post detailed pictures of this kit.
you can easily sell this kit if half of the van parts are there,
which I HIGHLY ENCOURAGE you to do,
the van freaks are a special breed, and will come out of pocket.
please help out some poor unfortunate van owner.
you can most likely flip this for a better turbo for your truck.
its highly likely someone has a complete truck kit they cant use.
you found the hens teeth, now turn it into a golden egg.
Julian Kalamaha
40
01-12-2021 08:36 AM
Diesel wyatt
10-13-2013 06:56 PM
