2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
husky floor mats fitment help
Old 01-17-2017, 05:07 PM
Luckyc1423's Avatar
Luckyc1423
Luckyc1423 is offline
I bought the countour mats from husky.
on the drivers side the mats fit perfect. on the passenger side something is not lining up right.
Has anyone had this issue? Should I return the passenger side mat?
Old 01-17-2017, 05:12 PM
Davparks2's Avatar
Davparks2
Davparks2 is offline
I have the same problem with my Husky weatherbeater mats. After a few days it did flatten out a bit but the hump on the passenger side rear of the mat does not seem to match up with mat exactly.
Old 01-17-2017, 05:14 PM
Luckyc1423's Avatar
Luckyc1423
another picture of the passenger side mat
Old 01-17-2017, 05:16 PM
Luckyc1423's Avatar
Luckyc1423
picture showing that the drivers side matt lines up perfect
Old 01-17-2017, 05:20 PM
Luckyc1423's Avatar
Luckyc1423
I understand that, but why would the drivers side mat fit perfectly and the passenger side mat be so off?
I totally get it if they both were off?
Old 01-17-2017, 05:52 PM
Davparks2's Avatar
Davparks2
i think this hump is problem
left side of passenger mat towards back is off as well on mine
i was not impressed with fitment. My drivers side is perfect as well.
Old 01-17-2017, 06:31 PM
whiteywhip's Avatar
whiteywhip
whiteywhip is offline
i hope my weather tech liners fit better then these......will know tomorrow
Old 01-18-2017, 01:15 PM
Davparks's Avatar
Davparks
Davparks is offline
Called and emailed Husky this morning. They jumped all over it and are checking into it. See response below. I will update with more information when it becomes available.
David,
Thank you for the e-mail! We have not had this brought to our attention before but will definitely check it out. The most common Super Duty models we find are XLT and Lariat models. King Ranch and Platinum models are less common at the smaller, local dealers in our area. I will follow up with our findings.
Thanks!
Steve Bower
Engineering Manager
Husky Liners
Old 01-18-2017, 04:56 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Hope Husky gets this resolved, because this looks like a tripping hazard. I know my wifie would hit that mat each and every time getting in.
Wondering if poor quality control on the passenger side?
biz
Old 01-18-2017, 05:06 PM
Luckyc1423's Avatar
Luckyc1423
I just emailed them and gave them the link to this thread to view the pictures.
hopefully they can get the passenger side fixed, and ship me out a new passenger side mat.
If not I will need my money back to buy a different brand.
I sure hope they can get it fixed as I like the looks and feel of them. Solid product assuming they get the fitment right.
Old 01-18-2017, 06:20 PM
TenTex's Avatar
TenTex
TenTex is offline
My Weather Tech mats fit like a glove!
Old 01-19-2017, 08:04 AM
BigJoeT's Avatar
BigJoeT
BigJoeT is offline
What is this mat clipping on to with those two circles? Mine doesnt have cleats on the passenger side carpet for me mat to clip on to like the driver side does.
Old 01-19-2017, 09:42 AM
JasonB1's Avatar
JasonB1
JasonB1 is offline
It doesn't clip to anything on the passenger side.
FWIW, I trimmed my Weather tech so the "Platinum" would show and it looks pretty good.
Epic had a thread on it and I followed his procedure.
Old 01-19-2017, 09:51 AM
mhoefer's Avatar
mhoefer
mhoefer is offline
The clips are for the drivers side to prevent the Matt being pushed under the brake and throttle and causing an accident. To bad they are not on both sides to keep the matts in place. I have the ford ones, they fit good, but don't extend out over the sill plate far enough to prevent some water getting into the carpet. Look at the pics of EpicCowlick trimming his Husky matts so the platinum lighting still shows, it looked like his fit a bit better?
Old 01-19-2017, 09:53 AM
Florit17's Avatar
Florit17
Florit17 is offline
My Weather Tech mats fit like a glove. . .
My WT's definitely fit better than the OP's Husky's.
On a side note, my WT's were delivered in sub-zero temperatures and when they came out of the box they wouldn't flatten out - even after running floor heat on the short drives I was taking at the time. Got to the point where the passenger liner was curled up 90 degrees at the door sill from the door pushing on it when it was closed. I ended up hitting it with a heat gun all over and it laid flat & tight within 30 seconds. It looked so good that I did the drivers side too.
Quick Reply: husky floor mats fitment help
