Center caps for 5x8 budd wheels
I'm looking to put center caps on my budd wheels. I don't know if there is anything out there that fits or do I need to fabricate something. The 1933 hubcap fits the 5 7/8" hole but the outside diameter is 6 7/8" and hits the lug nuts. I like the looks of the 33 hubcap and might attempt to shrink it. But would like to see if anyone knows of something that fits.
Phillip, I used '34-'38 truck hubcaps on mine. The front s screw in in place of the center bearing cap. I did have to make an adapter as they are too short on the thread side to reach the hub threads. The rear hubcaps are held on with two flathead screws that screw into the axle jack screw heads. On the earlier trucks, the jack screws were drilled and tapped for the hubcap screws.
Mark
Early Ford Store has TONS of used parts. Originally some of these parts were at Valley Ford Obsolete (North Hollywood), some were at Harold Looney's obsolete parts store in Stanton.
Looney (that's his real name!) bought out Valley Obsolete, moved the parts to Stanton. Then he sold out to his partner who then opened Early Ford Store in San Dimas (located in the original 1916 Ford dealership).
You might be able to save them if you removed and installed them by hand, but I think using the big impact wrench would ruin them. The torque required for those nuts is 450± ft lbs.
Yep. I'll try the anti-seize too if I can get them off without destroying them. The rear ones are very tight too.
Bob, they make a plastic tool to remove the covers. On Edith, I covered them with a rag and used a pair of large channel locks carefully to pull them off. That was the way we used to do it on the Peterbuilt back in the 70's.
I've got a big pair of Channel Locks I can try with the rag (why didn't I think of that?) Thanks Joe.
I also found these:
Rheal.biz - Video
https://www.amazon.com/Ken-Tool-3060.../dp/B000GPGOIQ
I also found these:
Rheal.biz - Video
