Alignment required with strut change?
Old 01-16-2017, 05:00 PM
78Truckster's Avatar
78Truckster
78Truckster is offline
I have a 2005 F-150 4x2 with 4.2L mojo. If I change the struts, is an alignment required due to slight changes in the top mount location? I plan on having it aligned but timing wise I may not be able to get it all done at the same time.
Old 01-16-2017, 05:47 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
No alignment needed. The camber/caster is adjusted at the lower control arm and toe is done at the tie rod.
jws24
1999 to 2016 Super Duty
01-16-2019 11:18 AM
ItsAFord55
04-08-2012 12:30 PM
firebug
11-18-2008 10:26 AM
shanesF150
1997 - 2003 F150
02-17-2006 05:44 PM
88grandmarquis
05-07-2003 08:24 PM
Quick Reply: Alignment required with strut change?
