Help
Help
I have a 2006 f350 6.0l. I was driving home from work and all of a sudden I had no gas pedal. It would stumble and die with a bunch of white smoke out the tail. It also is not using the turbo at all no boost. I have a edge monitor and the engine codes it's kicking out are in the picture below. I have a warranty but the dealership that we bought it from and the closet ford dealer is 30-40 mins away and they don't currently have a diesel mechanic to work on it so I would have to go almost 1hr 20 mins to get to the next dealer. Any help and will it hurt it to drive it that far?
P0341 CMP Camshaft position sensor A circuit range/performance (bank 1 or signal sensor) Camshaft sensor circuit P0404 EGR Exhaust gas recirculation control circuit range/performance Difference between command and actual exceeds a specified limit P0528 FSS Fan speed sensor circuit no signal Mechanical failure, short to voltage, open circuit, short to ground P0611 FICM Fuel injector control module performance Internal FICM failure P2617 CKP Crankshaft position output circuit Incorrect CKP signal
With all of these codes I would find someone close or have it towed to where you want to get it fixed. Its going to be expensive I am sure..................
Tugly
04-24-2012 06:20 AM
ToMang07
05-29-2011 10:43 PM
