Heater Hassles - Harumph
2004 Excursion with a 5.4L. Wife calls, says heater isn't working. I figure heater valve is dead, pop the hood, check connections and get ready to buy a replacement.
But my hand grazed the A/C line on the way out and it's ice cold & covered in condensation.
A/C is turned off (front and rear zones). Manual controls.
Why is the compressor running when it's shut off? I MAY have heater issues here (i.e., blend door, heater valve, etc.) but I suspect that the heater valve is being told to stay shut since the A/C is on.
Help?
Help?
I'm not sure about your 2004 but the owners manual for my 2000 7.3 states that any time the selector **** is turned to a spot that has two options such as the dash/floor or defrost/floor as well well as the Max AC and AC and Defrost the AC compressor well run. I have unplugged the connector (easy to spot right on the AC compressor) that engages the AC compressor for a couple of months during the winter without any ill effects.
madsonp
1997-2006 Expedition & Navigator
10-11-2008 07:04 AM
karljay
11-14-2005 10:08 AM
phantmlord
09-29-2005 12:11 PM
