Crunched my towing mirror this morning - shell replacement?
Had a bad case of the Monday mornings today and crunched my mirror on a street tree backing up this morning. All the guts still work and no broken glass, it just looks like the exterior shell is crunched.
Anyone know if you can purchase the exterior shell separately and replace it?
Hard to tell from this parts diagram.
Any advice and links to replacement parts and a DIY would be greatly appreciated.
Buy 2011 Ford F-250 Super Duty Parts | FordParts.com
The parts you need are not available as individual pieces. You have to buy a complete mirror whether new or from a used parts supplier.
OUTSIDE MIRRORS for 2011 Ford F-350 Super Duty
Since I cant buy the shell, it looks like its cheaper to buy two aftermarket equivalents than one new factory replacement:
https://www.google.com/url?hl=en&q=h...dms8TL5EmC6lpg
Might be worth trying, although mine has the ambient air temp sensor built in. Could be difficult to find a direct swap for the shell.
I'm leaning towards buying a high quality direct replacement aftermarket set for $750 then reselling the perfect OEM drivers side hoping to get around $350-400 for it to offset costs. The passenger side should be worth something too.
If it were me, I wouldn't go the aftermarket, but that is just me. I just looked on Autonation Ford website, and it looks like the OEM right side mirror assembly can be had for $863. Your existing mirror cover may be ok yet.
Mirror, RIGHT for 2016 Ford F-350 Super Duty|DC3Z-17682-MA : AutoNation Ford White Bear Lake | Parts & Accessories
EDIT: My link was for 2016. I see you have 2011. A little bit more expensive - $946.22, I see its the same one that Larry posted the link to a few days ago.
http://parts.autonationfordwhitebear...position=right
I.B. Washincars
1999 to 2016 Super Duty
02-04-2018 09:27 AM
