Evaporator
Evaporator
Gentlemen, looking for a C8TZ-19860-C evaporator for factory installed a.c. on a 69 f-250. The loser that tried to remove the a.c. assembly on this truck decided to saw through the evaporator lines in hopes this would help the case drop down. He should have tried the two bolts on the firewall first.
C8TZ19860C replaced C8TZ19860A. They were the correct numbers for 68/72 Bumps with factory integral air. None on any of the locators I use. None on evilbay.
If it is still good except for the nipples, I would investigate local Automotive A/C companies, radiator shops, or welding companies to find someone who can aluminum weld nipples back on. Or try contacting https://originalair.com/restoration-ford-evaporators. Maybe they can help.
tazerproof
17
12-31-2016 11:27 AM
gbakman
22
10-11-2016 05:39 PM
ronspolv
11-23-2015 07:02 AM
77 ford shortbed
06-06-2008 03:51 PM
ryanstruck
12-10-2001 07:12 AM
