Camshaft choice
Well, then I'll just have to accept that and make the best of it. Now you have me back to leaning towards the 320. Is there a particular maf that is commonly used for this upgrade? Just don't want to get stuck with something that won't work.
If it's worth it is relative to the owner. Are long tubes worth it vs shortys? Are ported heads worth it? Compression bump? If I'm the one you're asking, the answer is yes to everything including the extra lift.
This thing keeps growing. I will be going .030 over and looking to increase CR to somewhere between 9.5 to 10. I'm also kicking around stroking to 331 which will add some low end torque, but not sure what the cost difference would be compared to just going to 306. What other costs would be incurred with the stroker build? Just want to explore options before pulling the trigger and getting past the point of no return and wishing I had done it differently.
I know 306 it's just an overbore, but I do want to reuse the existing block. I know the 351 is a lot stronger and has a lot more potential but also adds a 100lbs and will share the cost of rebuilding my 302 but also have the added expense of buying it. To that end, just curious as to the cost difference between the 306 and 331. Both will get me to the 300 hp level, just trying to establish if the added cost of the 331 for the torque increase is worth it to me.
Parts collected so far:
Rebuilt GT40's
Scorpion 1.6 rockers (arrived today)
Head, Valve Cover, Oil pan and timing cover gaskets
Arp - head bolts, intake bolts, valve cover bolts
24# injectors ordered
Waiting to order cam/timing chain/gear combo and maf until I get more help with selection.
Still need to order oil pump.
So, if stroke it, I will still be cleaning the bore to 4.030 and also adding new rods and crank?
Rebuilt GT40's
#28
Yes, stroker kit will be a full rotating assembly. If you don't plan on boost down the road, get a cast crank and pistons...you won't need forged with rpm as low as you'll be.
http://www.coasthigh.com/Ford-347-Fl...66-sf-f347.htm
You can find a cheaper kit, but can't really beat that price with forged pistons
