Factory turbo install questions
Um, oil supply line on my factory turbo goes to the factory sender spot at the rear of the motor.
The return line from the bottom of the turbo goes to the CDR hole in the valley pan.
The CDR is relocated to the passenger side valve cover. The valve cover on the turbo trucks is a different part with a bracket for the CDR valve and a piece of metal on the underside which keeps oil from splashing up.
InsanePyro
01-22-2018 07:42 AM
kevind95
43
06-25-2013 08:56 PM
caveman 53
09-16-2009 07:06 AM
