Backup sensors...somethings wrong!
Old 01-15-2017, 10:58 AM
jimmystoys's Avatar
jimmystoys
jimmystoys is offline
Hi all. Searched for this but it can be exhausting. Easier to start a thread! Have a 2012 King Ranch. When I put it into reverse the backup sensor SOUND comes on continously loud and clear! Bad connection? Faulty sensor? Anybody have any thoughts? Thx for your input.
Old 01-15-2017, 07:10 PM
bobv60's Avatar
bobv60
bobv60 is offline
Are you sure they're clean
Old 01-15-2017, 09:33 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
Boondocker
Received 6,614 Likes on 2,725 Posts
On my current truck the sensor alarm will go off if there is a build up of ice on the inside of the bumper.
Old 01-15-2017, 09:37 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
I have an unlimited wash package. At this time of year if it's below zero or near zero and I have the truck washed, sensors get water on or in them and are funky until the ice melts. They fix themselves.
Old 01-15-2017, 11:13 PM
jimmystoys's Avatar
jimmystoys
Yes they are clean. I clean them regularly, hoping I might wipe something off so the sensors work, but, still nothing.
Old 01-15-2017, 11:17 PM
jimmystoys's Avatar
jimmystoys
However, it is around the freezing point. We'll see what happens in a couple days here when it warms up. Thats never happened in the past. We'll see if anything changes.
Old 01-16-2017, 12:33 AM
Dakster's Avatar
Dakster
Dakster is offline
Mine do that when I wash the truck and until it warms up or the truck is parked in a heated garage. If I don't wash the truck in the winter - like thru a car wash - they never malfunction just in the cold. Of course if snow, dirt, mud gets on them I have to clean them... I did have a sensor go bad on my 2011.
Before troubleshooting any further, wait until it warms up a bit.
Old 01-16-2017, 07:44 PM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Received 2,559 Likes on 729 Posts
I've had mine do that from the frost that forms when I park outside over night.
See if it goes away when they warm up
Old 01-18-2017, 08:46 AM
jimmystoys's Avatar
jimmystoys
It's definately warmed up now, but very, very wet! The sensors are responding better. What I mean is as I select reverse the long beep starts then mutes....a bit, then beeps momentarily, as it seems to try and resume a normal operation. Of course beeps increase as I near an object, so it is better. Seems to be weather related. I'll keep monitoring it. Thx guys for your input.
Old 01-18-2017, 09:01 AM
HRTKD's Avatar
HRTKD
HRTKD is online now
Boondocker
It might be a bad sensor. Have you looked to see if any trouble codes have been stored?
Old 01-18-2017, 02:26 PM
Dakster's Avatar
Dakster
Dakster is offline
HRTKD - This is one of those issues that sometimes has to be troubleshooted without a code to go by. At least my *LIMITED* experience with those buggers has been that they never throw a code when they go bad or there is a problem. Luckily, in Ford's they usually go off for no reason, rather than not going off when you are close to something. And I have just had ice/frost/dirt/bad connections too... In either case, no codes.
The dealer can "look" at the sensors individually and tell which one is being flaky, which means we probably can do it with Forscan/Torque Pro, etc... Now on my 2015, I can tell by the lights at the bottom going green, yellow, red in sections... So at least you know WHERE to start looking. My 2011 didn't do that. Don't know when that change was implemented either.
Old 01-19-2017, 11:05 PM
jimmystoys's Avatar
jimmystoys
I don't know whats going on with these sensors. When it was freezing out and salty thats when they were acting up. Later, it got milder and they were starting to act more 'normal'. Now it's mild and pouring rain and they're acting up again! I think the connections/sensors are becoming fussy as they age.
Old 01-20-2017, 12:40 AM
Dakster's Avatar
Dakster
Dakster is offline
Clean the connectors and put some dielectric grease on them...
You might end up having to replace them if that doesn't work.
Old 01-20-2017, 06:56 AM
Kafn8td's Avatar
Kafn8td
Kafn8td is offline
This worked on my '12 KR.
Old 01-22-2017, 11:16 AM
jimmystoys's Avatar
jimmystoys
Yesterday was a calm, dry, but cool day (5C or about 40F) in a long time and the sensors worked as they should! Obviously sensitive to weather as it ages. I will have a closer look at the connectors when the weather warms a little. Thanks for your input guys.
aero993
02-28-2016 10:02 AM
tcjhkbjt
03-10-2014 09:55 AM
nikiter
2004 - 2008 F150
01-03-2014 03:21 PM
puller45
04-23-2010 07:22 PM
jscarb2
02-15-2006 03:21 PM
Quick Reply: Backup sensors...somethings wrong!
