Mess in rear drums
Mess in rear drums
ive been looking for a cause for my soft/soggy brake pedal. I finally got under there today and saw some fluid on the rear driver side drum. I open it up expecting to find a blown wheel cylinder and I find oil...gear oil from rear differential maybe? Never pulled much apart on a rear before
1988 F350 dually, steriling 10.25
Axle shaft seal is right.
When you replace it, you need to get a special 'seal-in-seal' type, where the two mating surfaces are inside the seal itself. It's a Scotseal 34384.
If you use the stock type... it will still leak.
You also want to make sure to remove any and all rust from both seating surfaces, clean everything up real good. You don't want any rust providing a place for oil to leak out.
Here's a nice set of pictures I found:
TheDieselStop.Com - www.thedieselstop.com
Makes sense. Thank you for the replies. I'll start pulling it apart in a bit. Just waiting for the sun to start hitting driveway lol
I borrowed two hub lock nut sockets from a buddy. Dunno if they'll fit but that's what he had in his tool box. He said one fits Dana 44, the other Dana 60. If no luck I have another buddy with a full set of them that he can grab from work on Monday for me
lol anyone need measurements or any reference pics while I got it apart?
I suppose the good part about this is that if your rear differential ever locks up, you can just remove the axle shafts, put a plate(or a piece of plastic) over the open cap, and drive home using front wheel drive...
Nope, the axle end comes out with 8 bolts. Inside that is the nut to hold on the actual bearing assembly.
Ok, finally got time to work on this. Hub assembly is off. My instructions say to "carefully pry out the old seal." Anyone have a trick to doing this without messing up the bearing? It looks newish in there so I'm thinking the previous owner may have done this already but with normal factory seals. It's a Timken bearing under there and it looks pretty still
thoughts on seal removal with out harming bearing?
thanks
thanks
