Starter/electrical question
So, my old starter went out a month or two ago. I got a replacement from car quest. I bolted the starter up, and went to hook the batteries up, and it's like something shorted out, and the battery clamp arced and gouged my battery terminal. But when I unhooked the power wire from the starter, I can hook the batteries up no problem. I checked all the the wires in that area, and replaced the starter solenoid, just because it was old anyway. Same problem. So I got car quest to warrantee out the starter. The 2nd one didn't have a problem. It worked fine up until yesterday. On my way home from work, I had the radio on, and I used the turn signal, and all the electronics and guages went dead. Somehow, the truck stayed running till I got home. After I shut it off, I tried turning the key, and nothing. I checked the batteries, and they were hot. Checked them with a volt meter, and they were 1.4 volts each. I took them out of the truck, and after they cooled, they were at 11. I know I shouldn't throw parts at the problem, but I figured voltage regulator, and it was really old too, so replaced that, and warenteed out my alternator, because the bearing was making noise and giving me headaches. So I go to hook the batteries up, and it did the same thing as before. Unhooked the starter, and no problem. So my question. Since the starter is the common denominator, have you guys ever heard of that happening? Or should I be looking at other things?
Also, about a year ago, when my dad drove the truck, he had to do a quick hillbilly fix to get home, and hooked up a push button for engaging the starter, and I've never hooked that back up the right way. But the original starter that went out never had the problem the last two have had, so it's not that.
Received 3,102 Likes
on
on
on
yolbolsom
03-10-2003 07:27 PM
