High Cap Trailer Tow F250
Does the High Cap tow package on an F250 give the truck the same leaf springs as an f350 srw? The F250 doesn't seem to have enough leafs for my intended use. The following doesn't mention it but I'm hoping so. Any one know?
The Trailer Tow Package - High Capacity is optional on all F-250 models. Package includes:
• Increase GCW on diesel engine from 23,500 lbs. to 25,700 lbs.
• Max Front Springs
• Upgraded axle
• 20” Chrome PVD Aluminum wheels – LARIAT and King Ranch® only
• 20” Polished Aluminum wheels – Platinum only
Package requires 6.7L Power Stroke® Diesel engine.
• Max Front Springs
• Upgraded axle
The two leafs seem like it would squat too much. Have a gooseneck with miller bobcat and water tank on the neck. Also sometimes put a round bale up there on my ranch trailer (yea not ideal but i tow this on my ranch only). I put a lot of odd heavy stuff up there when i run out of trailer space on the ranch, have even had a ranger on my buddies gooseneck. Granted i will be using one of my work trucks to do all this, i need the ability to move this type of equipment when my guys and trucks may not be around.
Back to the original question will i be getting the same leafs as a 350 srw?
By an F350. Get the extra heavy service front springs and the max tow, including the camper overload springs, and then you get the rear sway bar. The axle and most other parts are the same, but the spring ratings and capacities are what's different. I can send you pics of my spring packs, for the difference in price I think the F359 is better for your heavy use. By the time you pay for the package above, you might as well.
Bottom line is maybe I should have gotten a 350. But I hardly use my truck for any work as I have several duallies for my business, and can use one if i need to move something crazy. I ordered 12/23 and just received my vin, so too late to change now. And my truck is not one ill find on a lot so it would be too long if i had to re order. Oh well, if I'm too scared to tow it in my 250, a 350 srw probably wouldn't help my situation. My dodges are slt's so i just needed a nicer truck to meet with and drive clients around job sites. Only reason i got a truck was just for the "emergency" when i may need to move a piece of equipment..... Either way, yes i should have gotten a 350.
Bottom line is maybe I should have gotten a 350. But I hardly use my truck for any work as I have several duallies for my business, and can use one if i need to move something crazy. I ordered 12/23 and just received my vin so too late to change now. And my truck is not one ill find on a lot so it would be too long if i had to re order. Oh well, if I'm too scared to tow it in my 250, a 350 srw probably wouldn't help my situation. My dodges are dodge slt's so i just needed a nicer truck to meet with and drive clients around job sites. Only reason i got a truck was just for the "emergency" when i may need to move a piece of equipment..... Either way, yes i should have gotten a 350.
The payload sticker is located in the drivers side door jam.
After a bit of reading, I'm thinking that the only way to get the 350 leafs on the 250 is to get the camper package which i didn't get. The difference between the 250 and 250 was like 1100, i guess ill donate that to air bags and onboard air. Anyone have experience with firestone bags?
reesestewww
2017+ Super Duty
24
06-29-2017 11:37 AM
