Ride Rite air bags?
I had them on my old F250 with an onboard compressor and gauge in the cab. Never had a problem with them losing air but when not towing I lowered the air to around 5-8 psi. Some guys use 2 fill points but if I hadn't of had the onboard rig I would have just tied them together with one fill point.They work very good.
I just finished installing the Air Lift 5000 Ultimate bags with a Wireless One compressor/manifold system. Not the same company, but same parts really.
Anyway, you can assume that the pressure is right at what you want it to be after setting it because if it is not the compressor should turn on again to bring it back up to where you set it. If you want to check the pressure manually, you can use a tire pressure gauge on a valve that is easily accessible.
I put a single manual fill valve at the license plate in case the manifold or compressor fail, but that is not a common problem.
And you may never with your set up. I had an in bed overhead camper when I experienced it. Thought I was going to lose it. Reran separate lines and it made a huge difference in cornering. The logic is solid, center of gravity vrs. weight are the big players here.
This can also occur from driving on a tilted surface, such as the crown of a road. It will happen when sitting still on a tilted surface in loads such as a tall slide-in camper or with large concentrated loads, such as a powered air compressor or large generator or welder that is an off-centered load.
I discovered this back with air shocks. early 1970's station wagon...
1972 Kingswood. 400/400..
came with single.. soon after, changed to 2 inlets.. isolated units.
I just installed the Air Lift 5000 system that has 1 manifold and 1 compressor that branches to 2 air bags and a manual fill valve in the rear of the vehicle. Is there an easy way to change this to a bag isolated or 2 part system without buying another manifold and compressor?
A quick simple, cheap solution would be to just put a shutoff valve between the tee and one of the bags.
. Open the valve before filling the bags. Do this when the vehicle is level side to side.
. Fill the bags to the desired pressure.
. Close the valve installed between the tee and one of the bags. The bags are now isolated from each other.
