What is this?
The crank case has moisture in it.
At certain temperatures and pressure the moisture mixes with the contaminants and .,.. condenses... on the coolest surfaces which is the oil fill cap, valve covers areas.
Run the engine to full operating temperature long enough to evacuate the crankcase through the PCV valve and hose.
The crank case is fed filtered outside air from the intake system but operating temperatures are the key to keeping this under control.
Good luck.
Good luck.
djhecker15
07-27-2010 01:11 PM
Madsan
09-12-2003 02:04 PM
