1970 F350 Cab replacement
Does anyone know where I would start looking for a cab for my 1970 F350? I was going to replace as needed the parts that have rusted and needed to be repaired floor and front cab supports - Those I have found. Then looking at things I noticed that the head liner was in need of repair -- after removing the trim and hard board I looked at the front window area to find the complete section (half round between the window and head-liner is past repair. I can not find anyone the sells a replacement section for this area. I do not have the correct equipment to try to reproduce the section. So with all that said it looks like replacing the cab with one in better shape to start would be the correct and less costly way to move forward. I put a hold on the start of my 54 F2 project to do this one first because we use this truck to pull are race car hauler. Any info would be a great help in my search for a replacement CAB.
2007 Ford F450 Crew Cab Dually with Regency Hauler Bed w/6.0 - 19.5 rims & tires SCT programmer. Towing 2014 Voltage 3950 Toy Hauler
1970 Ford F350 Cab with homemade flat bed Dually w/390ci- 420hp. Towing 32' race car trailer.
1954 Ford F2 work in progress.
Here is what I found within 300 miles.
1970
Cab Shell Assembly
Ford Truck F100
NEEDS FLOOR,ROCKER, BLUE-BLUE
000
A
$250
actual
ARichner Auto Parts USA-PA(Milesburg) Request_Quote 1-814-355-3851/ 1-888-572-3428 Request_Insurance_Quote
[IMG]file:///C:\Users\E145033\AppData\Local\Temp\msohtmlclip1\0 1\clip_image001.png[/IMG]
303
1970
Cab Shell Assembly
Ford Truck F100
SOLID FLOOR & SUPPORT
000
A
T10
$395
actual
303
1971
Cab Shell Assembly
Ford Truck F100
NICE FOR YEAR, GOLD-BLK/GOLD
000
A
$595
actual
303
1970
Cab Shell Assembly
Ford Truck F100
FLOORS WERE FIXED,YOU PULL, GREEN-BLACK
000
A
$395
actual
303
1970
Cab Shell Assembly
Ford Truck F100
actual
1970
Cab Shell Assembly
Ford Truck F100
T10
actual
1971
Cab Shell Assembly
Ford Truck F100
actual
1970
Cab Shell Assembly
Ford Truck F100
actual
DPDISXR4Ti
Ford Truck Parts for Sale
01-18-2015 09:31 PM
