which steering column for 53 F-100
Planning on installing GM 5.3 engine in my 53 F100 but need some guidance on what junk yard tilt steering column that'll work. Kinda wonder what'll work with a mustang II IFS that we have yet to purchase and install.. Any wisdom you'd care to pass this way would be appreciated... Anybody out there that has done this exact remod I'd love to talk with about pitfalls to watch out for...
Crickets . . . probably because of the perceived heresy of putting a bow tie in one of Henry's products Many of us have used either a Flaming River or an Ididit tilt column with the usual length being 30" with any variety of Ford engines. I have not used a junk yard column but I would think that whichever one you choose you would have to carefully cut it down to fit. If you are using a Mustang II IFS maybe a Mustang II column would be a good match. Probably still have to cut it down though.
on
As far as hooking them up I think anything can be made to work . I am running a junkyard 1999 Cadillac power tilt and telescopic which with your engine choice should make the wiring easier . I apologise as this is the only current pic I have . It has to exit the cab higher because of the angle it was installed in the caddy , I have a vette front , sbf and it clears my headers .
I used a tilt column that was common in the 69-72 A body GM cars. I rolled a stainless cover for the lower section to hide all the wiring. I eliminated the key and steering lock in the column. I considered using a column out of a Cadillac so I could use the telescoping feature too, but it was going to be harder to clean up.
If one is not using the stock steering box or a box mounted in the same location and angle as the original box then the position and angle of the replacement steering box is going to dictate where the column exits thru the firewall. There's a lot of steering options available for theses old trucks as we all know.
jays '56 f-100
05-02-2019 11:12 PM
Cg willie Willie
01-18-2017 09:14 PM
billhannah
07-08-2014 11:25 AM
allwthrrider
11-22-2010 10:28 PM
