Computer Chips & Tuners
FORD F150 - EXPLORER 1999 ECU MAPPING?
Old 01-09-2017, 08:55 PM
alejandroborja's Avatar
alejandroborja
alejandroborja is offline
Exclamation FORD F150 - EXPLORER 1999 ECU MAPPING?
Hi Friends, i need to know if is possible to modify, mapping, tuning a FORD EXPLORER 99, FORD F150 99 ??
because on ebay is too many software for ecu tuning, but i ask to the sellers and nobody know if is possible to use this software on 99 trucks
Galletto? CarProg? Kess?.. Genius???
Any person know??
Old 01-10-2017, 07:48 PM
Conanski's Avatar
Conanski
Conanski is offline
You can't change the basic powertrain configuration with a tuner you can only modify it some, so if for example the explorer had a 4.6L/4R70w combo you could use it with the same engine/trans in an F150 even without tuning, but you can't make a V6 PCM work with a V8.
JValdez
02-29-2008 07:41 PM
FLKIN
08-23-2002 09:45 PM
Quick Reply: FORD F150 - EXPLORER 1999 ECU MAPPING?
