F47 Dome light
01-09-2017, 12:59 PM
F47 Dome light
Does anyone know how the dome light is secured above the rear window? There is just a block of wood with a light built in, but im not sure how to take it down without damaging it?
01-09-2017, 05:50 PM
Light mounting
My interior light in my '50 F47 was attached to a wooden block that was secured to the rib of the back of the cab, above the window.
01-09-2017, 10:24 PM
Quote:
Originally Posted by
tip49
Thanks, how was the block secured to the cab? Mine is still right where ford put it.
01-10-2017, 10:26 AM
Dome light
If I recall correctly, it was screwed through the rib into the wood block.
01-13-2017, 11:36 AM
That's exactly how mine is done as well.
I was wondering if that was factory or not. Sounds like it is!
Kirk
01-15-2017, 11:10 AM
I got it down last night, the two screws were hiding behind the rear window seal. Has anyone taken their apart? I assume the stainless bezel unscrews.
01-21-2017, 01:35 PM
Bump
has anyone taken theirs apart?
02-12-2017, 01:54 PM
Manual
I took a look at the manual showing the dome light. Did not look at the light itself, I am using a light from my donor but the manual shows two screws on the trim late that allow removal of the trim ring and disassembly from there.
03-02-2017, 04:32 PM
Mines buried in a snow bank right now. So there is no getting into my cab until spring.
Kirk
dtgl90vt
06-16-2016 07:58 AM
dtgl90vt
12-28-2015 09:32 PM
lbrauer
08-06-2012 06:21 PM
jailbar
1947 and Older Ford Trucks
03-27-2011 07:09 PM
XLT-Lariat
01-25-2006 11:18 PM
