Cold Start (<32 deg) questions
Its my first "cold" season with my 97 PSD. Temps were in the low 30's the past 2 days and the truck has had difficulty starting up. Before i simply blame my injectors (287k on what I believe to be originals) I had a few questions
1.When I put the ignition and the WTS comes on/then off, do the glow plugs remain on? If so, how long?
2. How quickly should the truck fire up? It took me a couple glow plug cycles (I turned the ignition off/on 3-4 times just to make sure the glow plugs were firing) and it finally came to life.
What is your startup procedure? I'm curious to know what others do.
The glow plugs stay on for about 2 minutes on average, from what I hear. I usually just turn the key, wait a good 30 count after the WTS light turns off, and crank for 10 seconds MAX.
If it doesn't start, I do the same thing again. Usually it starts after the second attempt when it is that cold.
If you try to crank it for longer than 10 seconds, you could start wearing out your starter (over time), or kill the batteries before the truck fires.
What Jarrett says. Turning the key off then back on doesn't do any good. For a minute and a half to two minutes the glow plugs run. After the wait to start light goes off, try waiting for 30 seconds before turning the key to start. If it doesn't start then you probably need new GP's. Is your GPR working?
I assume my GPR is working since the truck starts up fine any other time above 32 degrees and cold. The truck fires up very quickly in any other scenario apart from being <32 degrees outside
^^^^^ +1 above, except 30 seconds is probably more than you need. When we're unable to plug in, we usually do a 10- or 15-count after the WTS light goes off, before cranking. The other obvious takeaway is that you should NOT "cycle" the key the way you described. That just opens and closes the GPR, leading to an earlier failure.
Of course, the best option is to plug in the block heater. Not really needed at 32F, but it helps a LOT. Plus your cab heat will be better, quicker. It's also much better on the rotating assembly to have some heat in the engine on startup. When we plug in the block heater for, say, 3 hours at 20F, the EOT is between 70F and 80F at startup.
I forgot to plug my truck in last night so I took a video this morning . 7F, 295k on original injectors I start it as soon as wts goes off. Smokes for a couple minutes then clears up. I just put all new glow plugs in because of of low temp starting issues. All 8 I removed were bad.
https://youtu.be/_X61ZaELUFg
I'll be sure to post my findings.
