1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Mileage/Compass display all lit up
Old 01-08-2017, 05:24 PM
ryanrob's Avatar
ryanrob
ryanrob is offline
Unhappy Mileage/Compass display all lit up
Hi there
I've owned my 2003 (03-06 model) Expedition XLT for the last year or so and has around 150,000 miles on it.
A month or so ago the milage/compass/temp display didn't do the usual 'blackout' fault, it's done the opposite and all the digits are lit up (see photo attached).
I can't seem to find anything on the net so far about this problem, anyone here able to shed some light on this?
TIA, Ryan
Old 01-09-2017, 09:06 AM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
I have to say that for that to happen the electronics are likely toast.
Old 01-09-2017, 04:04 PM
ryanrob's Avatar
ryanrob
ryanrob is offline
I'm hoping it's a similar problem to the blackout fault, e.g. bad solder connection. But I may be too hopeful! Anyone else with ideas?
Old 01-10-2017, 10:59 AM
Skauber's Avatar
Skauber
Skauber is offline
The best thing you can do is to remove the instrument cluster from the truck and disassemble it. Then inspect the solder joints, use a good magnifying glass. Fix any joints you find to be suspect, but this is likely not your problem. After this you can thoroughly clean the board, use an electronic cleaner or similar. If you're lucky, it's just buildup of crud over the years that finally has become conductive. If you're unlucky, then you have to find a replacement or send it to a service center. Or if you happen to be an electronic engineer, take a crack at fixing it yourself..
As long as none of the specialized ICs are damaged, the rest is somewhat simple to replace and repair, but it requires you to know what you're doing of course.
Ardvaark
1997 - 2003 F150
03-11-2016 02:28 PM
anah go karts
2004 - 2008 F150
07-11-2012 07:39 PM
w5kgt
Electrical Systems/Wiring
09-18-2008 10:49 PM
SarERob
07-16-2008 05:08 PM
Quick Reply: Mileage/Compass display all lit up
