Dual gas tank switching question
The PO of my truck had a lot of fuel system work done by a questionable repair shop. My switch for tanks works fine and my problem is the front tank always shows empty while the rear tank reads properly. There is gas in the front tank and it runs fine in that switch selection but it is showing empty. Is there anything I can repair for this issue other than pull the tank? Thank You. Sandy
"Runnin on empty"
It would appear the gauge circuit is not connected properly. Check continuity at all points accessible outside of the tank. If all is correct you may need to get inside the tank since it is likely either the sending unit or float assembly may have been damaged or not even properly connected. From what you describe I would highly suspect this to be the case. Until you have the time to look into it I would suggest you fill both tanks each time you refuel and draw from the front tank, using your trip odometer & your approximate MPGs to keep a close guesstimate of how much fuel your have drawn from that tank. Better to underestimate that MPG figure to minimize running the tank out of fuel which is hard on the pumps since they actually use the fuel flowing through and around them to keep them cool.
dn.
dn.
Perfect................I was hoping you wouldn't say that. In the interim, do you agree about filling both tanks? I never use this truck except to run short errands so two tanks in unnecessary. If I don't fix the float wouldn't it be better to run the front tank dry and from then on just use the back tank? Thank you again.
Mine does the same thing, except if i run on the front tank it will pump fuel into the rear tank. I just fill up both tanks, use the rear tank until its almost empty. Then switch to front tank & within a half hour it will fill rear tank. Then use the rear tank. Always heard its not good to run the tanks dry since they use the fuel as a coolant.
bmxerbrett
05-31-2016 08:24 PM
AKHunter93
06-06-2015 06:47 PM
Hunt4Fun
11-30-2007 07:44 PM
