Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
"Adaptive" Transmission
Old 01-07-2017, 02:19 PM
got2bjoester's Avatar
got2bjoester
got2bjoester is offline
Anyone else have an adaptive transmission that appears to act like a manual?
On acceleration, rpms go up, drop slightly while shifting, then up again after shifting...
If you didn't know better, it sounds like a manual transmission but isn't. No slip, no bogging, just... well, manual-like.
I do go very easy on the gas when accelerating normally so I'm wondering if this is an expected shifting pattern?
Old 01-07-2017, 10:35 PM
wptski's Avatar
wptski
wptski is offline
I think you are describing a "shift flare" or clutch slippage at shift points.
Old 01-07-2017, 11:30 PM
Torky2's Avatar
Torky2
Torky2 is offline
Yup. Expected. With the 6F35 transaxle and the electronic throttle body, the PCM controls engine speed and shifting. In light to moderate acceleration, it's like a little guy is behind the dashboard, shifting a manual transmission. As long as he keeps doing it well, all's OK.
When we had the throttle body problem as I posted on here a year or more ago about, then shifting and some other operations went into a fault-management mode, then it wasn't so good. I put on a new throttle body and did the retrain procedure, and all has been fine since.
It IS fun to listen to, under lighter acceleration up to higher speeds, all the "manual" shifts!
Old 01-08-2017, 10:04 AM
got2bjoester
wptski - nope, not flare. this is definitely throttle down, shift, throttle up on accelration.
Torky2-
The Escape had been driven by many and I think it was confused when we first picked it up. Dealer assured us it was mechanically sound. After maybe 100 miles it started doing this and as you described, it's like a little guy in the engine room is shifting the transmission based on the throttle position indicator set by the captain on the bridge.
..and yes, it's kinda cool. I'll see if I can record and post it.
Old 01-08-2017, 10:36 AM
wptski's Avatar
wptski
wptski is offline
Yep, I misread!
Old 01-08-2017, 09:18 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I rented a Mustang from Hertz in California in ~2005 that did this, I thought it was cool.
Old 01-17-2017, 09:06 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
My ex's New Beetle Convertible would lessen the throttle on upshifts as well, but it had horrible throttle and shift point programming to the point it almost got me run over a few times. At 25 merging onto the freeway, you'd floor it, and the thing would do nothing for literally a second, like it wanted to be sure you meant it. Then it'd go full throttle in 4th gear, downshift really quick 3rd-2nd-1st, hit the rev limiter a few times in 1st, then slam 2nd and start actually accelerating. Terrible disconnect to the actual throttle movement as well.
Luckily the Fords are a bit better.
brentkhack
2015 + Expedition & Navigator
12-03-2015 01:27 PM
PIGGEONFLIER
1999 to 2016 Super Duty
11-28-2015 11:42 PM
Hiflyer746
09-26-2009 03:58 PM
WWBeast
01-11-2006 10:30 PM
alan2244
1997 - 2003 F150
12-16-2004 08:30 AM
Quick Reply: "Adaptive" Transmission
