1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
6.0 dies when hit brakes or turn wheel
Old 01-07-2017, 02:45 AM
jmccart's Avatar
jmccart
jmccart is offline
Hey I'm having an issue I just can't seem to make sense of, 2006 f350 6.0 once it's been running for a min or so it will die when brake is pressed, also dies when you turn the wheel. Can't find any rub through or bad wiring.if you up rpm slightly it will not die with brake or steering. Tried removing belt thinking it possibly was a pulp and it doesn't die with the brake or steering but will die when going from drive to park. Thinking possible cps anyone see anything aimilar?
Old 01-07-2017, 09:06 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Isint the brake and power steering on a hydraboost system,,,?
Old 01-07-2017, 09:46 AM
jmccart's Avatar
jmccart
jmccart is offline
Yea still dies with belt off, when putting in gear
Old 01-07-2017, 04:01 PM
erikkloss's Avatar
erikkloss
erikkloss is offline
It sounds like it is stalling anytime a load is put on the engine. Not sure if this applies to your situation:
Ford TSB: 2005 Stall When Engaging Drive or Reverse, or at Stops, TorqShift Only:
Trucks built between 10-1 and 11-30-04 may exhibit a stall under the above conditions, along with various shift solenoid codes. This may be due to a sticking torque converter control solenoid. The transmission pan should be cleaned out, the TCC solenoid (3C3Z-7J136-BA) and external fluid filter replaced, and the cooler flushed and flow checked. TSB 05-12-1.
NOTE: These conditions may occur on vehicles outside of the build dates above. However, the same repair applies, although the solenoid part number may be different.
Old 01-07-2017, 05:09 PM
jmccart's Avatar
jmccart
jmccart is offline
It doesn't lug it down shuts down like the key is shut off. Will do just turning wheel and or hitting brakes
Old 01-07-2017, 05:15 PM
FordBlueHeart's Avatar
FordBlueHeart
FordBlueHeart is offline
That sounds similar to how a remote start works when the brake is applied w/o the key in the run position.
Old 01-07-2017, 05:17 PM
jmccart's Avatar
jmccart
jmccart is offline
Yup same idea, no remote start tho
jmccart's Avatar
jmccart
jmccart is offline
Sometimes will die when idling then start up and die a few times others idle for hours but if I up to 1000 rpm never does
Old 01-07-2017, 05:21 PM
FordBlueHeart
I figured as much. I don't see that you have a "signature" at the bottom of your posts(Like mine), how about you post up some information about your truck, whether or not you have the ability to monitor any PIDs or the background on your issue. Is this a new issue, intermittent, temperature dependant and so on.
Old 01-07-2017, 05:24 PM
jmccart's Avatar
jmccart
jmccart is offline
Does it consistently have snapon scanner, very familiar with 6.0 engines but this one has me stumped
Old 01-07-2017, 05:27 PM
FordBlueHeart
Are gauges doing the "sweep" when it happens? Have you replaced the FICM relay?
Another thing I would suggest is asking a moderator to move your thread to the 6.0 section. A lot of the guys don't spend time on the Super Duty subforum.
Old 01-07-2017, 05:43 PM
jmccart's Avatar
jmccart
jmccart is offline
Yes and checked hpo readings, it throws cam and crank codes sometimes but I'm thinking that's just caused by stalling and restarting
Old 01-07-2017, 09:05 PM
FordBlueHeart
Yes it does the sweep, yes to replacing the relay or both? What are your readings? Is it retaining FICM sync?
Old 01-09-2017, 10:24 AM
FordBlueHeart
The OP started a new thread on the 6.0 section. Here's a link.
https://www.ford-trucks.com/forums/1...ee-turned.html
jmccart
10-10-2023 03:16 PM
Mcrafty1
06-24-2014 05:21 PM
americanford89
05-18-2012 03:17 PM
forq2
03-28-2006 12:05 AM
Quick Reply: 6.0 dies when hit brakes or turn wheel
