2016 F150 Lowering Shackles
Might want to give these shackles a try...
2015-2016 Ford F150 Lowering Kit
IMHO...they look like high quality.
biz
biz
2016 f150 2in lowering shackles
hi need help with finding lowering shackles im wanting two in drop i have some on now but they are noisy creaking a lot plus dont think they are for my truck had to modify top bolt hole to fit factory bolt
im looking for some that use factory bolts and not noisy lmk thanks
biz
All links wont pull up for me keeps saying cant be found lol but i got the ones i have on now from ebay and they said they work on my truck but had to modify them and they did good till a few days after they started creaking so i just want some that use factory bolts and no noise issue that some one has used and can give a direct link or name part number..... And has any one used the ford performance ones on a 2wd does it give a 2 in drop cuz it says 1.5 but for 4wd but they have blocks so since 2wd dont shouldnt it be 2in on 2wd sry for the book lol i work at ford so i get a discount on them but wanna see if anyones used them and how r they
Ahhh, I see. I just tried the links in post #10 and #18 and they worked fine.
Crown Suspension Lowering Kits Lift Kits Airride Leveling Kits
If the link doesn't work for you...just copy and paste into a diferent tab in your browser. Or do a GOOGLE search for crown suspension.
Good luck!
biz
Good luck!
biz
#28
On the crown suspension u have any issues and does it use factory bolts and did u have to grease it sry for being to much trouble just dont wanna get them and they have to be consistently lubed want same as factory install and ride no noise or up keep
............ If u can find the ford performance that did 2 in lmk and is urs 2wd or 4wd do u have pics of ur truck and any issues noise
Mykal Lange
12-30-2015 10:11 PM
96F150EB
03-28-2011 03:40 PM
santi2322
16
02-21-2010 11:56 AM
bearster18
10-15-2007 11:59 AM
