2000 f450 wont turn over
hey guys i have a 2000 ford f450 with the 7.3. the truck sat for about three month and now it wont turn over. when i put the key in to start it only the airbag light and abs light up. when i got to turn it over i can hear the starter just click but the engine wont crank. i have checked the batteries and the starter and they are all good. i have also checked the shiftier position sensor on the tranny and it fine. any ideas would be awesome
First isolate the problem to see if it is the starter. You can disconnect one of the cables on the starter solenoid (located on the passenger fender) and touch it to the cable on the opposite side of the solenoid. If your cables and batteries are good, this should engage the starter. (make sure its locked in park and e brake set)
w74bronco
01-22-2014 07:59 PM
idylmoments
01-13-2014 01:27 PM
meierw1
15
12-12-2012 10:28 PM
eddie v
12-07-2010 04:27 PM
Ponyboychris
75
06-21-2009 10:48 AM
