Brake Light and Abs Problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-27-2003, 01:26 AM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
I have a 94 ranger 4.0 4x4. One winter while 4 wheeling I happened to get into some snow that just kept getting deeper until i got stuck, So i had to back out, after doing that i noticed that the brake light and the abs light were on, then for about a year after that it would just come on and go off. For the past 6 months it has stayed off untill you press the brake all the way down to the floor , then it comes on. If you shut off the truck and restart it it will be off untill you press the brakes all the way down again. if you get the light to come on and drive with it like that, then when you shut it off and turn it on it will still be on and wont come off until the truck cools down. there is nothing wrong with the brakes, new calipers, new pads, and no leaks that i've noticed. I was told the rotors look a little thin though. I dont know if this is related, but it seems when you start the truck after driving it with the light on, it will idle rough or even stall. but after you rev it 3-4 times it will run smoothly. any help would be great.
Old 08-27-2003, 09:52 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Hello, welcome to FTE!
You probably should try pulling any codes from your ABS system. I believe there is an ABS test harness connection under your hood, probably mounted on the firewall somewhere. Might have to get a shop to hook up to it to get the codes.
Assuming you have 4WABS, one possibility could be that your rear ABS sensor was damaged, or the connections to it were messed up, when you backed out of the snow. The sensor is mounted on the rear axle housing. You can actually take it off rather easily and clean it up, just unplug the electrical connector (clean up the electricl connections, too) and remove the one bolt that holds it in place. Spray the sensor with electrical contact cleaner, and wipe off all the particles from the magnet part of the sensor. Lubricate the rubber O-ring with motor oil when you reinstall it. And remember to take the cable off the negative terminal of your battery before you do the job.
Good luck.
Old 08-27-2003, 10:41 AM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
I believe you would have RABS, if you do there is a procedure for pulling the codes in the tech info post. I agree with rockledge, the VSS is the most likely cause.
Old 08-27-2003, 12:36 PM
Rockledge's Avatar
Ken is right, there is a difference between RABS and 4WABS. A method for pulling codes from an RABS system is here: Pulling RABS Codes.
If you do have 4WABS in your '94, the way to pull codes from that kind of system is as follows:
«1994 Aerostar/Ranger/Explorer Table of Contents»
«Group 06: BRAKE»
«Section 06-09B: Brake, 4-Wheel Anti-Lock»
«DIAGNOSIS AND TESTING»
Light Flash Technique
NOTE:
If 12V test light is not available, the ABS warning light also flashes during this test.
1. Locate test connector in the engine compartment and install 12V test light between Circuits 603 (DG) and 57 (BK) in the test connector.
2. Key OFF. Connect a jumper wire between circuits 57 (BK) and 606 (BK/LB in the test connector.
3. Key ON. Observe test light.
4. Remove jumper between Circuits 57 (BK) and 606 (BK/LB) in the test connector after five seconds.
5. Count light flashes of test light or ABS warning lamp.
The DTCs are flashed out in most significant digit, then lease significant digit. The digits are seperated by 3-6 seconds and DTCs are separated by 15 seconds.
Example: The lamp flashes one time, pauses 3-6 seconds, flashes seven times, pauses 15 seconds, flashes six times, pauses 3-6 seconds, then flashes 3 times. DTCs output: 17 and 63.
Old 08-27-2003, 11:50 PM
Peter94's Avatar
Thanks for the Info, I'll try pulling the codes tommorow, I'll probably post them late around 10 or 11 on (8/28). By the way i have RABS. One thing i dont understand is why the light only comes on if i push the pedal all the way down to the floor. I can drive forever with it as long as i dont have to slam on the brakes and i'll never see the brake light, but as soon as i slam the brakes down it'll pop on. I always thought as if it was the vss the light would come on at random?
Old 09-06-2003, 07:05 PM
Peter94's Avatar
Sorry it took so long to get the codes, anyway, it flashed 15 short and 1 long repeatedly, with the engin running. otherwise with the engine off but still in run position, all it would do is flash 3 short and 1 long repeatedly, Hope this helps with the problem, thaks
Old 09-06-2003, 07:43 PM
Ken00's Avatar
16 is the pass code, 4 is the RABS valve switch closed or open dump valve. Email me if you want the pinpoint tests for the code.
Old 01-03-2005, 09:10 PM
Steve77 Steve77 is offline
Steve77 is starting off with a positive reputation.
I seem to be having the same problem with my Ranger. It's a 1994, 2wd, super cab with a 4L v6 engine. When I start up the truck the ABS and Brake lights are off but after using the brakes for awhile the lights come on, but the brakes still feel the same. Any help or advice would be appreciated.
Old 01-03-2005, 09:22 PM
Ken00's Avatar
Welcome to FTE!!!
Pull the code, I have the procedure in the tech info thread at the top of this forum.
Old 01-04-2005, 10:10 AM
Peter94's Avatar
Yeah, my light just kind of went away. I'm not sure what ever became of it. oh well.
Old 01-04-2005, 01:23 PM
richind richind is offline
richind is starting off with a positive reputation.
I had a similar problem last year (2000 Ranger XLT 4x4x4). I got into some good
snow, and got a little wild in it. Not sure of the exact sequence, but somehow
between using 4WL and 4WH, and squirrling around, I set the ABS light. It seemed
to happen when the truck got into a "bindup" (got down to good traction in a tight
turn) situation.
The ABS was definately off, since you could hammer the brakes in the snow and
get all the wheels to lock and slide. Gone too was the pulsating, when putting
the pedal down hard.
Even after leaving the truck parked for a few hours and then starting it back
up again, the ABS light stayed on solid. They next day however, it was back
to normal, and has never acted up since (and ABS is working).
Old 09-08-2005, 09:57 AM
the_bob the_bob is offline
the_bob is starting off with a positive reputation.
Anybody know if the above procedure works for retrieving codes on a '99 Ranger?
Old 09-08-2005, 08:00 PM
Ken00's Avatar
For RABS you use the procedure in the tech info thread at the top of the forum, 4 wheel ABS requires an ODB-II scanner.
Old 09-08-2005, 08:54 PM
I was actually talking about the post by Rockledge on 08-27-2003. It seemed like he was talking about a procedure for 4WABS. If an OBD-II scanner gives up ABS info on my '99, though, that would be even better. The guy at AutoZone claimed their OBD-II scanner would only read "Check Engine" codes, but I do know someone who has a scanner. Thanks!
Old 09-09-2005, 08:01 PM
I got ahold of an Actron OBD-II scanner, but alas, I am still without my precious ABS codes. So, I'll pose the question again... Does anybody know if the procedure posted by Rockledge on 08-27-2003 still works for a 1999 Ranger? Please? Anybody?
Can't get RABS codes nijwnfi Ranger & B-Series 10 12-28-2012 07:50 PM
ABS comes on after release brake pedal at startup redsly 1997 - 2003 F150 4 07-10-2012 08:22 PM
ABS and BRAKE lights on? boggerted 1987 - 1996 F150 & Larger F-Series Trucks 16 09-04-2010 11:39 AM
ABS Light on, not sure whats wrong speedyejl 1997-2006 Expedition & Navigator 4 04-21-2010 02:38 PM
Brake light and ABS light stays on alfasteve 1968-2013 Full Size Vans 5 05-21-2009 11:03 PM
Tags
2000, 97, abs, brake, brakes, connector, diagnosis, f150, flashes, ford, light, problems, ranger, test, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
