1999 Ranger Start Issues
Old 12-11-2012, 12:56 PM
hcraw4d's Avatar
hcraw4d
hcraw4d is offline
Question 1999 Ranger Start Issues
So a couple days ago I started my truck and it fired up like normal, but then sputtered out and died after a few seconds. I tried starting it up again and it did the same thing. I tried once more and it started up fine and I drove away.
It sounds like my truck is running out of breath or something and just sputtering out. Runs fine once it turns over though.
My issue is that it is happening almost every time I start it now. I have to turn it a couple times before it catches. Any thoughts on what this might be?
Old 12-11-2012, 02:14 PM
cracked block's Avatar
cracked block
cracked block is offline
You provided to much information for anyone to help you with your problem.
Old 12-11-2012, 03:12 PM
hcraw4d's Avatar
hcraw4d
hcraw4d is offline
I provided too much information?
Here's a summary:
Engine starts then stops.
After stopping a few times it runs.
Old 12-11-2012, 03:26 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to FTE.
Next time it acts out on a start, cycle the ignition key from off to run 5-6 times, while listening for the fuel pump to turn on for a couple of seconds & cycle off but don't crank the engine, then go to start to crank the engine & see if it'll start & run normally & let us know what you find.
Old 12-11-2012, 03:49 PM
hcraw4d's Avatar
hcraw4d
hcraw4d is offline
When I turn the key to battery, the fuel pump does turn on. If I let it sit in this position for a few seconds, it does start up normally.
Side question, how come only one side (passenger) unlocks when I hit the button on my key while the driver's side just makes a noise like it is unlocking?
Old 12-11-2012, 04:01 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
OK, well if you find that you have to cycle the switch from off to run a time or two, to have it start & remain runing, it could mean that the fuel pump is getting weak, or that the fuel filter needs changing. The filter is scheduled for changing every 30K miles, so if its time for a change, do that first & see how the start/run problem goes.
On the door lock problem, will it work ok when the engine is running????
Old 12-11-2012, 04:44 PM
hcraw4d's Avatar
hcraw4d
hcraw4d is offline
The door will unlock via key, but neither the button on the remote or the inside switch will unlock it.
I'll change my filter and see how it goes.
Old 12-11-2012, 05:11 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Here's a summary:
He was saying you didn't provide enough.
At this point we don't know if your truck is a 4x4. We don't know if it's an automatic or a manual - we don't even know which engine it has.
Old 12-11-2012, 05:59 PM
hcraw4d's Avatar
hcraw4d
hcraw4d is offline
My bad. 1999 4x4 4.0L V6 Sport model. Nothing aftermarket on the engine/tranny.
Old 12-11-2012, 06:09 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
OK, now when the engine is running, will the door switch unlock the drivers side?????
Old 12-11-2012, 06:14 PM
hcraw4d's Avatar
hcraw4d
hcraw4d is offline
The lock will only work manually, regardless of whether or not the truck is running.
Old 12-11-2012, 06:54 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
OK, what I was trying to find out is if the lock would work at the higher voltage that the alternator puts out, so as I understand your post it won't work electrically at all, engine running or not, right????.
If you can hear it try to work, check the door lock ground connection thats located behind the drivers side floor kick panel.
sparks250
1999 to 2016 Super Duty
07-12-2019 11:57 PM
Mike1998Ranger
Electrical Systems/Wiring
09-13-2013 07:41 PM
screwy
Modular V8 (4.6L, 5.4L)
01-03-2008 10:31 AM
MazdaNoZoom
06-27-2004 10:25 AM
Quick Reply: 1999 Ranger Start Issues
