Replacement carpet / vinyl floor
I did end up going with the ACC/stock interiors carpet with the thicker backing option. Quality is good, I went with a darker gray than the stock light gray color to hide dirt a little better.
The fact that it doesn't have any holes and needs trimming is a killer though, it took me an entire Saturday to get it in the car and the interior more or less in.
One other issue that I noticed is that with the extra backing the carpet under the throttle just barely clears at WOT. The floor mats I have will not fit undearneath. I'm hoping with a bit of break in it will settle a bit.
It would not be economically feasible for them to make the holes in the carpet for you. Do you have a manual or auto trans. How about manual or auto transfer case? Do you have both or just one of those shifters? I used a technique that I saw on a show about partially installing the bolts for the seat belts and seats and using that as a guide for cutting an X in the carpet. On my Jeep I had to cut the outer edge to get it to clear the bracket in the kick panel area. I also purchased floor mats and the combination is too thick for WOT. I have removed the mat for now until the carpet relaxed a bit more.
For my pickup and the girlfriend's ZX2 I removed the carpet and cleaned it with the carpet cleaner machine.
https://www.ford-trucks.com/forums/1...er-carpet.html
Do you still like the carpet you got? Would you buy the same brand, with the thicker backing? I have my seat out and will probably try to clean the carpet but it looks terrible. Thanks.
Dennis Peacock
11-27-2014 11:55 AM
chadbob
03-31-2014 11:01 PM
AK FORD GUY
26
12-24-2010 10:36 AM
1975Ford
09-15-2005 05:14 PM
