2002 F250 Wheel Setup
Hi Guys,
Im looking to replace the factory wheels on my 2002 F250 with a leveling kit. I was wanting to go with an 18x9 or something in that range. I found one I like with 0 offset, so 5" backspacing. From the searching I have done, I am not sure a 5" backspace would cause rubbing on the leaf spring or not. Anyone running this setup?
Also, anyone running 18x9's with -12 or 0 offset, please post picture.
Thanks in advance!
Thanks in advance!
17x9 with -12 offset. 295-70-17 tires. Truck has a 1 inch taller block in the rear and a leveling kit in the front. No rubbing on springs or fenders. The only rubbing is on my molded plastic mudflaps which could be easily solved by putting on some flat rubber mudflaps. Tires stick out about an inch from the body.
Deuce338
1999 to 2016 Super Duty
05-15-2015 04:50 PM
