Trans shifting
I realized shortly after posting that yours is a v8 with AWD not 4wd ...oops.
Yes your transfer case has clutches but when they go out you feel them rumble around corners when you turn on pavement.
That's what sent my 2000 down the road.
Drive it a couple weeks and see if it gets better. If not, it may be time to have a transmission shop check it out.
A thought, does this trans have bands in it? Maybe they are loose in the gears slipping? (If there are in fact any) Just shootin in the dark now.
5-6 searching until I get to hwy speed at first no rumble just searching 35 to 45 mph, had oil and filter changed now rumble getting worse. Don't run out of OD in city but will now to try to run it longer.
Brought it to a tranny shop to put additive in it, they found out the short yellow dip stick was broken. No way to know how much oil in it except over fill and let it come out till it stopped. I went and bought the dip stick from ford and brought it to the new trans shop to check how much fluid in it. At the same time add Dr Trannys trans shudder fix. They found it to be 2 quarts low on fluid, added that and tranny shutter fix, it took about 2 miles to get back in shape, shortly after no shudder and no problem. 35-40 mph trans unsure where it wants to be in 5or6 but working great might be computer glitch, who knows, doing great now. No codes, no worries. Thanks for all the info and help on the Forum much appreciated. Geo.
Thanks, I thought I would need to turn OD off in the city. A lot of good help and advice on the forum. I am going to enjoy driving it....be safe and enjoy.
Found this thread in the f150 forum.
https://www.ford-trucks.com/forums/1...l#post16958393
Sounds similar to yours. Might be something to check out; lots of similarities between the 6r80 and 6r60
Jon351m
12-15-2011 05:02 AM
7DF250
07-26-2011 09:05 PM
