49 F1 rear spring u-bolts
I've been driving the ole truck some and am concerned about the pinion angle. I can live with it but don't want to damage any seals or anything. Engine angle is about 3 degree down but the stock rear end is way high. I was thinking of shimming between the springs and axle. What I need to know is what are the problems associated with this. Is there an easier way of doing it. What about the small center spring pack bolt. Where do I buy slightly longer U-bolts if I add shims. Lots of unknowns. Thanks
I have an angle finder and finding the proper angle is not a problem. The stock rear end just naturally is angled higher than wanted. What about the small center bolt in the spring pack. It will almost certainly break before coming loose. I don't want any surprises when I cut those old u-bolts off. Thanks for the replies
sammie0126
01-17-2013 07:39 PM
npccpartsman
08-07-2009 09:37 AM
49willard
03-08-2006 03:14 PM
